Is adding more rams cause issue for the laptop?
can i add more ram up to 2x16gb rams instead of 2x8gb rams?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The short answer is yes.
The laptop supports up to 32GB i.e. 2 x 16GB of DDR4L-3200 PC4-25600 ram
Here's the maintenance and service guide for the laptop. Go to p.39 to view the procedure to replace the memory
Here's a supplier that confirms that it will work
このアンサーは役に立ちましたか?
There should be no problem adding memory
Just make sure the DDR and MHz match the processor's specs
You can see it on Intel's website
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 69
