Why are my coils freezing up
This is a side by side model.
Freezer works fine, but fridge can't keep up.
Every 2 weeks I have to take back off of freezer section and use a blow dryer to melt ice off of coils.
Tips?
Hi @gary87126,
What is the model number of the refrigerator?
Seems as though there's a defrost problem. This could be caused by a faulty defrost heater, faulty defrost thermostat, block drain leading from below the evaporator unit in the freezer to the evaporator pan under the compartments or a faulty defrost timer or control board.
Knowing the model number will help to narrow it down to what the problem is and also if replacement parts are required then the correct ones for the model can be shown
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 20
今までの合計 62
