メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The all-new GMT900 generation of the Silverado/Sierra arrived in the last quarter of 2006 as a 2007 model. It features a redesigned exterior, interior, frame, and suspension as well as a power increases on certain engines.
My drivers window doesn’t roll down or up. The switch just buzzes
Window doesn’t roll up or down the window button just buzzes when trying to use the window controls. I was having issues with the passenger window also. I replaced the switch panel and that fixed the passenger window but the drivers window still buzzes and won’t move.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I can't answer your question directly, but I can offer some advise. Think like an electron. You need to do some testing. Is there power to the switch? It sounds like there is, but is it sufficient? Make sure it's 12 volts. If it's getting to the switch, is it getting out of the switch? Is power getting to the motor? If it is, you may need to replace it. The last place you detect power is probably where the problem is. There may also be sensors involved; limit switches and the like. I used to have a truck where that would happen, but letting the motor cool would allow me to close the window eventually. I hope you find the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 31
今までの合計 222
