After replacing with new battery phone is not starting
How check phone is dead or not
Check to make sure it is a legitimate battery. Also, if it's dead, it won't turn on. Try charging it, the turn it on again. If it doesn't work, try the old battery again to see if the new one has a fault. Hope this helps!
このアンサーは役に立ちましたか?
Try checking to see if there is still protective plastic on the battery copper
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 28
