Why is my battery not charging
Trying to start the engine in the morning is a problem
Hi Billy,
I don't have any specific knowledge of your car in particular; rather this advice is all applicable to most any car with the same kind of problem you're having.
So you get up in the morning and the car won't or has trouble starting due to the battery being low is what I'm hearing; correct me if I'm wrong. If that's the case, then you've got three main things to check to figure out what's going on with your car.
That should give you a place to start to get your CX-3 fixed. Check out the things I've mentioned and let us know what you find.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 10
過去 30 日: 45
今までの合計 289
