メインコンテンツにスキップ
Released 2006, identified by model number E1705
10回答 すべてを表示
締切られた回答
screen not working correct most the time
when i start my laptop, its seems like at the fisrt moment runing well. and windows XP log showed, but suddenly the screen comes with some rubish like some noise in the picture not noise a sound, and stuck in this this without continue runing show desktop or evenable to see the desktop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I had similar problems with my dell.
It was in warranty repair several times, but problem still there, never working properly from the very beginning.
Everything was replaced by warranty several times! Video card-2 times, motherboard-1, screen-2 times, hard drive-2 times, etc.
Now i got another problem- half working or nonworking screen.
Fed up with this dell already.
さんによる
コメントを追加
2件の回答
最も参考になった回答
abbas, use an external monitor and see if that makes a difference. You can also download a Linux Live CD, I prefer Puppy Linux, and start your computer from the CD drive. That way you can determine if it is hardware related,i.e. inverter, backlight or LCD problems, vs. hardware settings in Windows. If the problem only happens while you are running Windows, check your display settings, and refresh your driver. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Please help me I need as possible to the VGA card and the battery does not find them in my country
さんによる
@hamdy, this laptop does not have a separate video card. It is part of the motherboard and can not be replaced by itself. The battery is widely available at places like Amazon etc.
さんによる
thanks alot but i need the amazon email or another
さんによる
コメントを追加
Re install your OS using following steps:
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start booting from USB).
Step 8- follow the on screen instructions to complete the windows installation. Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 742
