wont start up properly
My iMac wont start up properly just a small file comes in the middle of the screen with a head in it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
your Mac is likely having a problem either finding your startup disk or the system software. it may be a hardware problem with your disk drive, or just corrupted OS files on the disk.
try booting from your OS install disc - hold the C key down with disc inserted while you reboot.
then after booting, go to Disk Utility (in the Utilities menu) and try repairing your disk volume. if repair is successful then reboot and see if everything is ok. or you may need to try re-installing the OS
if you can't even mount or see your internal hard drive in Disk Utility, then it's probably a defective hard drive.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 8
今までの合計 1,918
2 件のコメント
Could that be a question mark instead of head?
mayer さんによる
yes a question mark sorry
angie さんによる
