メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年2月に発売されたSamsungのAndroidスマートフォン、Galaxy A32 5Gの修理および分解情報です。
How come during calls no can hear me unless I put it on speaker mode?
No one can hear me when I call them unless I use speaker mode. Why is that?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi Dan,
Generally when we see this sort of issue, it's because one of the microphones built into the phone has failed; in this case it's the one at the bottom of the phone that's used when you make a phone call. By putting the phone in speakerphone mode, you're transferring the microphone input to the one at the top of the phone near the earpiece speaker.
Samsung suggests the first thing to do is, of course, to reboot the phone to make sure it's not a glitch. If that doesn't do the trick, they say you should try it in Safe Mode to make sure it isn't a bad app causing the problem. Here are their instructions for putting the phone in safe mode.
I've had trouble locating repair guides specifically for your particular phone, but Step 19 of the screen replacement guide here on iFixit shows the part that holds the lower microphone. If the problem is indeed a bad microphone, then replacing that part should get you going again.
Samsung Galaxy A32 5G Screen Replacement - iFixit Repair Guide
画像
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @danava,
Just to add to the answer above, use a vacuum cleaner to clear the voice inlet hole, located on the bottom edge of the phone, in case it is clogged with lint or dust.
Do not use a pin or probe to try and clear it as you may damage some of the internal components which are directly behind the hole.
さんによる
コメントを追加
回答を追加する
Dan Ava さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 36
過去 30 日: 84
今までの合計 1,414
