メインコンテンツにスキップ
Released on October 1, 2013, the HP EliteBook 850 G1 is a high-end business laptop. Repair guides and detailed information can be found here.
4回答 すべてを表示
laptop blinking light 9 times without turning on
my laptop blinks light 9 times when without turning on when i plug in AC adapter. But when i remove the battery and plugged in my AC adapter, the power and capslock lights and the charging lights constantly blinking without turning on.
what should i do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Which lights are blinking and what pattern ? This is important as they are giving you information about the state of the computer.
Click this to take you to a site from which you can down load the HP Elitebook 850 G4 Service Manual which should fairly similar to your model.
Page 92 is a good place to start for the various lights.
Take note of how to do a reset and check all connections inside.
Just found this link for Elitebook 850 G1 manuals
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Charging light blinks white lights 9 times and won’t turn on. When I remove the battery, on AC the power, charging, power button and cap lock lights be blinking constantly
さんによる
コメントを追加
Before heading to a repair shop, try doing a hard reset: unplug the AC adapter, remove the battery, then hold the power button for about 30 seconds. Plug everything back in and see if it turns on. If not, might be time for a professional look.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have done that already and it still didn’t work
さんによる
コメントを追加
回答を追加する
xperience piro さん、ありがとうございました!
統計データ:
過去 24時間: 13
過去 7 日: 43
過去 30 日: 209
今までの合計 1,082
