メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
How to copy contacts to SIM card?
How can I copy my contacts from the iPhone (3GS) to my SIM card so I can have a copy of it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
2 件のコメント
Is it a jailbroken phone. I recall that you can do it with an app if it is jailbroken, if it is not than you can not do it. Well, unless you have a Nokia phone as well, then there would be a workaround.
さんによる
Yes, it is a jailbroken phone. Do you remember the app's name so I can do it?
TIA.
さんによる
コメントを追加
10件の回答
ベストアンサー
iPhone does not support directly copying of iPhone contacts to the SIM memory. Easiest would be to
1.Transfer iPhone contacts to PC
2. Use a third-party SIM manager program in combination with an external USB SIM-card drive for your PC in order to save the iPhone contacts from your PC to the SIM card.
3. You are all set!
Having a jailbroken iPhone complicates matters, as you cannot use iTunes to sync your iPhone contacts to Outlook or Windows contacts in order to transfer the contacts in both steps 1. and 2. you need to use third-party programs.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
You cannot copy iPhone contacts to the SIM. The iPhone does not store or reference contacts on a SIM. The iPhone contact format is not compatible with a SIM; it has a lot more information than a SIM can contain.
The way to protect against crashes is to sync your iPhone to Address Book on your computer on a regular basis. This is how the phone is intended to be used.
You can copy contacts to another iPhone by syncing with Address Book on your computer.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
As I know , you can not copy your contacts from the iPhone (3GS) to SIM card, but you can transfer your data, including photo, songs, videos and playlist and more. The program allows you to back up and restore all of your iPod, iPhone, iPad or iPod Touch content like your favorite songs, videos, photos, play lists and more.
If you want to protect your data, you can try to use iPhone transfer tool.
Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
この回答は他の質問に帰属しています。
While copying contacts to sim some contacts if data loss occurs then you can recover them back to your iPhone 3GS by applying iPhone 3GS contacts recovery tool. This tool is free to use. So apply it and get your inaccessible data back. Download this tool for free from http://www.iosdevicerecovery.info/iphone...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Moshe Epstein, there are iPhone applications that allow you to transfer your contact information from your contacts list to your SIM card. The iPhone will have to be a Jailbroken one, for the apps to work. The ones I know are Simanager and iSim. iSim was originally for the original iPhone, so you might have to check on it. Here isa description on how to do it. There may of course be other apps, so you might need to look around. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it coule be done via simanager from cydia, its a free app.....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Actually, this is very easy and simple to do.In this case first of all you will go to the menu in your phone.Then you will go to contacts.After that you will click on the names option and go to and click on the mark all option.Next you will click on the copy marked option and click on the from phone memory to sim card option.Then all contacts will be copied in your sim card. You can also use this way to transfer contacts from iPhone to outlook.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
how to go to names option after being on contacts?
さんによる
コメントを追加
この回答は他の質問に帰属しています。
You can use FonePaw iOS Transfer or iTunes to transfer contacts to iPhone. As for iTunes, you can also connect your iPhone to the computer which has iTunes on it and you can sync the contacts to PC. As for FonePaw iOS Transfer, you just need to connect your iphone to the computer and then choose the contacts and transfer them to iPhone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
Let me say, you can use MobiKin Assistant for iOS software to transfer contacts from iphone to computer. It work well and you can transfer various data from ios device to computer, like Contacts, Text messages, Photos, Music, Video, eBook, Notes, Safari Bookmarks, Voice Memo, Podcast, Ringtone, Playlist, etc. You can have a try!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If your SIM card supports it, you can import SIM contacts to your iPhone. Learn how.
iPhone doesn't store contacts on the SIM card. If you want to transfer contacts between iPhones, you can use iCloud to backup or transfer content between devices.
Import contacts stored on a SIM card
If your iPhone isn't using the SIM from your old phone:
1. Make sure that the SIM card from your previous phone can fit into your iPhone
2. Remove your iPhone SIM card and replace it with the SIM card from your previous phone.
3. Tap Settings > Mail, Contacts, Calendars > Import SIM Contacts.
4. Wait for the import to complete.
If you swapped SIM cards in step 1, remove the SIM card and replace it with your iPhone SIM card.
Open Contacts and make sure that the contacts imported.
The contact information imported from a SIM card depends on how your previous phone stored information on the SIM card. For more help with importing contacts from a non-Apple phone, check the manufacturer’s website, app store, or contact your carrier.
More information you can read here:
Whatsapp Recovery
Recover deleted whatsapp messages from iphone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Moshe Epstein さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 247,254
