メインコンテンツにスキップ
Joy-Conは、ニンテンドーSwitchゲームコンソール用のコントローラーです。
167回答 すべてを表示
Joystick works except for other buttons when shell is closed
I got my Nintendo Switch since its launched in March 2017. Just a year later, the LED indicator and the SL+SR buttons on my left joy-con stops working (aside from the joy-con drift problem). I did not care that much since I only play single player games and mostly on my Switch Pro Controller.
Now that I have my own family, I wanted to play Switch with them. So I tried to fix the left joy-con by replacing the SL ribbon cable and joystick. I knew I was successful because the LED indicator lights up again and the SL + SR button are being detected. My problem is when I try to put back the shell. If the joy-con shell is closed tightly, only the joystick is being detected, the rest like the d-pad, L, ZL, etc. stops working. Loose up the shell slightly, all the buttons will work again.
Can you help me with this problem? I would appreciate your support on this.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Case could be closing on one of the cables for those buttons or something is not properly put in right
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arbiti さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 61
