メインコンテンツにスキップ
2022年2月に発売されたSamsungのスマートフォン「S22 Ultra」の修理・分解情報。
Broken screen but S-pen works perfectly
Today i dropped my phone, bottom half of my screen is yellow/black/sometimes display recovers for a short time. I can barely use my fingers on the bottom half to do anything, but the S Pen works perfectly, even where the phone dropped and the screen is cracked. How is that? is the S-Pen display under the touch display ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hello Radu,
Your phone has another screen layer known as the digitizer. It essentially keeps track of where the tip of your pen is when you press it on the screen. The software in your phone communicates with the pen and displays what you write or tap on your screen. While it sounds like your top screen is damaged and doesn't respond correctly to touch, your digitizer is still working independently with what's inside your pen.
I hope this helps answer your question.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
So that means that the display is broken and needs to be changed, but the pen works nonetheless. Correct?
さんによる
コメントを追加
回答を追加する
Radu Bejan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 298
