Touch screen not working
How to you working touch screen
My screen is not working
このアンサーは役に立ちましたか?
@vijaydas36031 do what is suggested in my original answer.
@aakendrasunar there are a few things you can try first. Make sure that you have the latest software updates download. You do that by Settings > About Phone > Software Updates > Download and Install > and check there. If nothing is to be downloaded you have the latest software.
Of course, you also want to check on the things that Samsung recommends on here My concern with those is that you may not get into your phone if you can't access any menus etc. due to a failed touchscreen
I would go ahead and replace the display assembly to which the touchscreen is fused to. Since iFixit does not have a guide for this use something like this video to work on it. Replacement screens are readily available at many online stores. Just make sure you get one for your exact version.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 17
過去 30 日: 72
今までの合計 303
3 件のコメント
White screen
shoyebsheikh さんによる
No touch I touch but screen no touching
Sahil Natha さんによる
@sahilnatha do what is suggested in the original answer.
oldturkey03 さんによる
