Why is there space on top?
Whenever Im printing, it leaves too much space on top of the paper and the remaining content gets cut off on the bottom of the paper.
Even though I don't own this printer, I do own a printer which used to do this before. Have you tried to "Calibrate" the print through your printer's settings? Is the page size set correctly in the settings? [If your printer is set to print on a different sheet instead of the current sheets you have, this could be it.] Are the settings set correctly to print? Are the pages set to print in "Portrait"? [Sometimes "Landscape" can cause printing to cut off]
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 123
