The AC power adapter wattage and type cannot be determined
Alert! The AC power adapter wattage and type cannot be determined.The battery may not charge.
@mykah if you are using a 3rd party AC adapter you want to go ahead and try to find an original Dell adapter. Clean your DC in jack with a few puffs of canned air, make sure there is no corrosion, bend pins, debris that may cause these issues. A faulty DC in jack can give you those errors as well. consider replacing it if nothing else works. Number one cause is not using a Dell adapter.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 132
