メインコンテンツにスキップ
これらの交換部品ガイドを使って、Samsung Galaxy Watch Active2を修理しましょう。
49回答 すべてを表示
The appearance of the word "reboot" after submerging it in water, and
I was swimming in the pool when the word 'reboot' appeared on the screen, and then the screen stopped working. I tried to restart it, but it was no use.
Note: Some time has passed since this incident.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@abdullaziz85196 sounds to me like your watch may have taken on some water. I would treat it the same way as I would any other water immersed device.
The very first step I would take is to disassemble your watch. Use these guides Samsung Galaxy Watch Active2 to help you disassemble your smartwatch. Take a close look at all components and connectors. Check for major corrosion, evaluate the pins in the connectors etc,. If you need to use water to clean any gross contamination, use sterile water. Take a look at all connectors as well as cable ends. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your watch as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Also, you do not need to leave the parts to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your smartwatch and re-evaluate.
Samsung Galaxy Watch Active2 Motherboard Replacement
Samsung Galaxy Watch Active2 Battery Replacement
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
Samsung Galaxy Watch Active2 Motherboardの画像
ガイド
難易度:
中レベル
35 minutes - 1 hour
Samsung Galaxy Watch Active2 Batteryの画像
ガイド
難易度:
中レベル
40 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Abdullaziz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 61
