メインコンテンツにスキップ
The Nokia N70 It is equipped with a 2 megapixel camera with built-in flash, a front VGA camera to allow video calling, FM radio, and Bluetooth.
9回答 すべてを表示
締切られた回答
My phone memory is full but it's empty
Text Message:
Not enough memory to perform operation.delete some data first.
This notification appears when i add a contact to my message.That's why i can't use messaging.and it appears too when i try to delete some of my contacts.Need help please?:(
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hey its a simple problem Try this...
First Go to messaging then go to Settings.... then in Settings... Textmessage ... Select Save messages.... 999 Or Wat ever maximum number it allows...
then in same settings .. "Other"
Then Message memory Select ... Card memory...
Hey if you have taken any songs Or etc. via bluetooth then this problem may occur...
2.If you have any Software... Like SELEQ or FILEMAN...Or Fexplorer Then you can eaisly tranfer the files From phone memory to card and it is advantageous....
Then just go to phone memory then system then Mail then open each file Copy it From there and paste in card memory....
Then file Pasted in card memory just delete From Messaging..
You will not lose your any data
Hope u will get succcessssssss...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,665
