My uh6150 doesn't power on at all
Hello. my uh6150 doesn't power on at all, i've replaced both the main and power bards, still doesn't turn on at all, even replaced the power cable. Should i swap out the T-con board as well?
Contemplating replacing the power supply board on mine, as it will not turn on at all anymore after i removed the power cable at one point to turn it off.
Update (12/30/23)
Here are the pics, sorry. Just getting back to this now. Both boards are the new replacements installed and of my multimeter
I do now get a blinking red LED at the bottom of the TV, after it's been plugged in. But still doesn't power on, and i've also tried other outlets
5 件のコメント
@vincentmagallon what are the first 2 numbers for your TV model. LEt's see if we can figure this out. A bad T-con board would not prevent your TV from coming on.
oldturkey03 さんによる
Hello. Thank you for responding, it is 55UH6150
Vincent Magallon さんによる
@vincentmagallon Do you have a multimeter so we can check some voltages?
Andrew S さんによる
Yes i do, but i don't know really how to use it, nor where to use it on these boards.
Here are the pics, sorry. Just getting back to this now. Both boards are the new replacements installed and if my multimeter
