oven is working but all the elements are not
all the elements are not working, ovens are working time clock are too
Update (10/09/23)
Here’s a photo of the diagram:
The oven is a Frigidaire model made for Kenmore.
As best that I can find out the technical data sheet for the model series 970-6784* which would have the wiring diagram etc is part # 316458450 (supplier example only)
Unfortunately I cannot find a free download online. You may have better luck.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
I’m sorry the model # is incorrect but what I have is schem. Diagram # 316904412 rev. B thanks
Do you need help reading the schematic?
I cannot find a free download online but if you can scan it, post the scanned file of it in your question above and I will try to help you navigate through it.
Here's how to add images, (it is the same procedure for documents etc) on ifixit
I sent you a schematic diagram hope you’ll be able to help me
OK
What is the model number of the oven and do you have a DMM (digital multimeter) and know how to use it safely when testing for potentially lethal AC voltage?
Yes I have a multi meter, anyway did you receive the diagram I sent you
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 123
