@aaronjosep48927 Turn your multimeter to the 20 VDC range (if you need help with this, upload a picture [ iFixitでの質問に画像を追加する方法 ] of your multimeter and reply to this comment). Plug your power brick into the wall, then into your SNES. Find a component labeled "U12" or "IC12" on the motherboard. Touch the black probe to the middle pin and touch the red probe to either side. You should have about 10-18 volts on one side and 5 volts on the other. Let me know what voltages you get.
@aaronjosep48927 Do you have a multimeter?
Andrew S さんによる
@andrewsawesome ya I checked pretty much everything
Aaron Josephson さんによる
@aaronjosep48927 Did you check to make sure that the voltage regulator is working properly?
Andrew S さんによる
@andrewsawesome I actually did not where is that located and how do I check it?
Andrew S さんによる
6件以上のコメントを表示
