メインコンテンツにスキップ
The Lenovo ThinkPad X250 repair page provides detailed guides on how to replace the battery, RAM, storage, and thermal paste. Additional information to help you fix your laptop on your own is also included.
I have a black screen problem
The laptop turn on but I can't see nothing except the black screen, how can I fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hello Sir can you tell me? here are some issue i have Lenovo laptop x250 i5 5th gen. issue is dim screen how to i fix it
さんによる
Hi @brotherste23795
Depends what you mean by "dim".
Have you tried pressing the Fn + F6 keys (both together) a few times to see if the screen brightens?
If it doesn't brighten then you may have a backlight problem.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @rees95027,
Try connecting an external monitor to the laptop's vga port or mini DP port and check if you get a display on it after starting the laptop. Don't forget to press the F7 (or Fn + F7) key to toggle the display between laptop only, external only or both on together.
If there is a display on the external monitor, then switch the display back to the laptop screen and then shine a flashlight at an angle close to the screen and check if you can see any images at all. They will be very faint if they are there so trying this in a darkened room may help.
If you see images on the laptop screen then there's a backlight problem. Either the backlight power supply on the motherboard, the video cable between the board and the LCD panel or the LCD panel.
If there are no images on the screen, then there's a problem with the video cable or the LCD panel
If there's no display on the external monitor, then either the laptop's not passing POST (Power On Self Test) on startup or there's a motherboard problem.
Here's the hardware maintenance manual for the laptop that may help if you have to disassemble it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rees さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 33
今までの合計 508
