Brother MFC-J4535DW Is this printer 5G compatible?
I can’t get the printer to connect.
Hi @rleiter
According to the printer's wireless specifications (Wireless LAN) it is IEEE802.11b/g/n compliant.
IEEE802.11n means it can be compatible with either 2.4GHz or 5.8Ghz WiFi. It depends on what Brother decided to use
IEEE802.11b/g means it is compatible with 2.4GHz WiFi only.
If the printer can't detect the 5.8GHz WiFi network, e.g. SSID of WiFi network is not shown in setup, then presumably it is only 2.4GHz compliant
If the printer can detect the 5.8GHz WiFi network e.g. SSID of WiFi network is shown in setup, check that the correct password has been entered in the printer's WiFi settings.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 80
