Please tell me how to increase the magnification of this camera furthe
Coolpix P500's 36x magnification is not enough for me! I would like more magnification. Please tell me how to increase the magnification further!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
As far as I know unless you want to buy a camera with more magnification you cannot just add it to your camera. However you can add a lens that allows you to have a longer focal length, which means more magnification. The Nikon Coolpix P500 allows you to add different Nikon as well as third party lenses using a 67mm adapter. This video helps with attaching your adapter which is just basically a metal tube. Then you can choose for a lens and here you have a wide variety so you can really choose what is best for you. Good luck ^-^
このアンサーは役に立ちましたか?
So what should I buy?
If you look for “nikon coolpix p500 67mm adapter” you can find various ones which should look like a metal tube (some websites are out of stock). KnF https://www.kentfaith.com/feature_nikon-... should still have one however unfortunately I’m not familiar with Nikon cameras and their compatibility between different camera lines
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 37
