メインコンテンツにスキップ
Why is my laptop keyboard is not working
my hp laptop ProBook 6560b's keyboard and mouse is not working.first when i turn on the pc the keyboard works well but after i press enter at the start windows the keyboard and mouse doesn't work
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Have you tried plugging in an external USB keyboard and mouse to see if they work?
さんによる
@aactech yes the external mouse is working but the external keyboard don't
さんによる
コメントを追加
2件の回答
ベストアンサー
Here are some possible solutions.
Do they work in the BIOS page? If yes then it could a Windows driver issue. Check in the Device Manager. They may have or not have an exclaimation mark by them. Regardless just uninstall them and let Windows re-install them.
The other thing could be the keyboard locking. Not sure if on your model. Try pressing and holding the right Shift key for 8 seconds. Doing this should unlock the keyboard. One of those "features" on some HP machinies!
Turning off Cortana also sometimes helps.
Disabling ctfmon.exe (Windows Collaborative Translation Framework), which is for multiple input methods, may also work.
Another thought. Does the onscreen keyboard work? Look in Settings.
Let us know how it goes.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Has someone worked on the laptop and opened the case? If so, it may be a simple as the keyboard is not plugged into the motherboard.(We should be so lucky).
If the external and the internal keyboard don’t work, the translator chip needs to be replaced.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nati さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 375
