メインコンテンツにスキップ
Repair information for the HP EliteBook 840 G3. This Hewlett-Packard laptop is designed for enterprise usage.
Why is my brightness level is not responding
Brightness controller is not functioning
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
In my experience, this is often due to issues with your graphics driver. A simple check for a Windows driver update might help. Press the Windows Key and X. Select Device Manager from the menu that appears. Find the display adapters section and pop it open. You may even see it's open already if the issue has been detected by Windows.
Right click whatever your computer has listed as the Display adapter. Likely for you it will be an Intel Graphics device. Select Update Driver to see if a newer driver is suggested by Windows.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Semir さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 365
