Why is my over flow tray always filling up and not the cup
When I make a cup of coffee a lot of water ends up in the overflow tray.
When I do a descale, most of the water ends in the overflow tray instead of the container I place under the spouts.
It sounds like you have a problem with your Breville Dual Boiler BES900 - BES900XL. There are a few possible causes for your overflow tray filling up and not the cup, such as:
To fix your problem, you will need to identify which part of your machine is causing it and replace or repair it accordingly. You can use some tools and methods to help you diagnose and fix your problem, such as:
I hope this information helps you solve your problem. If you have any questions or issues, please let me know. 😊
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 11
今までの合計 71
