Why my back camera and flashlight not wrking?
Why My back camera and flashlight is not working?
I'm going to disagree with @kingofspades regarding the two components you're having trouble with. The rear cameras are on two flex cables, one for each camera, while the flash is on a completely separate flex cable along with a microphone and the buttons on both sides of the phone.
I haven't encountered this myself, but I've heard from others on here that it's not uncommon for the flash to be disabled when a camera is malfunctioning. The camera replacement is fairly straight-forward so my suggestion would be to try replacing the rear cameras first then reevaluate.
iPhone 7 Plus Rear-Facing Cameras Replacement - iFixit Repair Guide
I suspect that once the camera is working again the flash will recover by itself, but if not you may have to consider replacing the flash/volume/microphone flex cable. Unfortunately iFixit doesn't have a guide for that, but the Spanish site Nadie Me Llama Gallina has the one you need.
Manuales / Apple iPhone 7 Plus / Flex buttons, microphone and flash
You can get the parts you need right here on iFixit if you want to support their repair efforts.
iPhone 7 Plus Dual Rear Camera
iPhone 7 Plus Audio Control Cable and Brackets
If you are budget conscious you can easily find less expensive parts on other sites like Amazon, eBay and AliExpress.
Good luck; let us know how it goes!
このアンサーは役に立ちましたか?
I see! I satnd corrected and will delete my answer. I dont mean to mislead anyone.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 14
