The engine is not started
The engine is not started and also blink blink in the head of midle merror
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I’m sorry to hear that you’re having trouble starting your Mercedes-Benz. According to Autotent, there are several reasons why your engine may not start. Here are some steps you can take to diagnose the problem:
If you are comfortable with DIY repairs, you can try following these steps to diagnose and fix the issue yourself. However, if you are not comfortable with DIY repairs or if you have any doubts about your ability to fix the issue yourself, it’s best to call a professional repair service.
Regarding the blinking lights on your rearview mirror, a fast blinking directional signal on a Mercedes indicates a bad bulb. However, I’m not sure if this is related to your engine issue.
I hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 20
