メインコンテンツにスキップ
2017年6月8日に発売。A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor.
Trying to replace the Blade SSD
Hey guys,
Have an iMac 21.5 (early 2017). Unfortunately, the built-in pci-SSD broke. have now ordered and installed an owc Auro Pro X2. Everything according to iFixit instructions. Has everything worked perfectly until then. Unfortunately the utility does not recognize the new SSD as a target volume. What can I do? Does this have to do with the firmware from apple?
Before the defect macOS 10.13 (high sierra) was installed. So according to notes from OWC current enough to install the new SSD for the host computer to recognize it.
Thanks a lot
Manu
Hey guys,
Habe einen iMac 21.5 (neuwertig im Jahr 2017). Leider ist die eingebaute pci-SSD kaputt gegangen. habe nun eine owc Auro Pro X2 bestellt und eingebaut. Alles gemäss iFixit-Anleitung. Hat bis da alles perfekt geklappt. Leider erkennt das Dienstprogramm die neue SSD als Zielvolume nicht. Was kann ich tun? Hat das mit der Firmware von apple zu tun?
Vor dem Defekt war macOS 10.13 (high sierra) installiert. Also gemäss Anmerkungen von OWC aktuell genug für den Einbau der neuen SSD, damit der Host-Computer diese erkennt.
Thanks a lot Hey guys,
Thanks a lot
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You’ll need to create a bootable USB thumb drive using another Mac system. The issue you are facing is do to Apple upgrading the file system from HFS+ to APFS and to add to that Apple also altered the OS’s PCIe/NVMe driver between Sierra and High Sierra which is why the OWC drive won’t show up.
Here’s how to get the OS installers How to download and install macOS
And here’s the steps to convert it to be bootable once you copy it over to a GUID formatted USB thumb drive Create a bootable installer for macOS
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi Manu,
Dan must be right. Your MBP is probably the last model to have a removable SSD. In my recent experience, this SSD can be moved around between Mid- 2013 MBAs and Mid- 2015 MBPs. I've moved 3 of them in the last couple of months.
And recovered their data using Carbon Copy Cloner. Al 3 were Apple originals.
APFS must be your issue!
Try and start up from your Recovery partition ( command R at startup), open Disk utility and see if you can format/ partition your SSD as APFS.
さんによる
@bartvsndessel - To clarify this is an iMac system.
I should have clarified the reason the macOS version is even an issue has to do with what version Apple gives you via Internet recovery. Which is the older Sierra release.
All older Mac systems face this issue as Apple failed to consider people using a SSD blade drive over the spinning Iron SATA HDD or even SSD.
If EM had a dual drive setup then upgrading the SATA drives OS to something newer than Sierra would also work then using Disk Utility to setup the blade drive, then to finish things alter the startup disk setting to the blade drive if that is the end goal.
さんによる
コメントを追加
回答を追加する
emtheman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 147
