メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
upgrade to more modern logic board a1278
hi
I bought a MacBook Pro a1278 primarily as a DVD player but am a writer and love the case, keyboard etc
can you get a more modern logic board that would work with this chassis?
I have tried google without success!
thank you in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@trencesmith unfortunately you cannot. The issue is that Apple keeps on changing the layout of the logic boards. Connectors, cables, RAM , etc are all different and in different locations etc. The only close board that will fit is the Mid-2012. It needs some minor mod on the LVDS connector since it is a little to wide for this board MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board Cost, amount of work etc are all a factor on this. You really will only have minor performance improvement. So, you are kind of (mostly) stuck with what you got. Keep using and enjoying it for the purpose you bought it for, "primarily as a DVD player"
Replace a 2.9 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 3.0, Audio In/Audio Out, SD card slot. Fix processing issues like unexpected shutdowns, reboots, or water damage.の画像
製品
$155.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
trence smith さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 179
