メインコンテンツにスキップ
A simple feature phone by Nokia released in 2012, identifiable by the model number RM873, or as the dual-SIM version RM872.
18回答 すべてを表示
Lcd led not working
I have nokia asha 206 and this problem is that the lcd,led is not working iam check the keypad rows bottoms led nots this problem I have also installed a new one lcd, but the problem is led coil. Please tell me how solve it my personal data and mesg missing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@muzamil13935 if you have not setup your phone to connect to a computer via USB for file transfer, there is not much you can do to get your files. At this point you really have not much to loose. I Suggest you take a look at the motherboard to see if you can determine which part is for the backlight/LCD and try to repair it. Use this Nokia 206 2060 Rm 872, Rm 873 SM to work on it and here is Nokia 206 Dual Sim And 206 Rm 872 873 Service Schematics V1.0 and the boardview.
If you have any issues with that, take some good pictures of your board and post those with your questions. that way we can see what you see and hopefully help you further.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Muzamil さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 184
