Missing components C5C 11,12,20,21,22
Missing components: C5C11, C5C12, C5C20, C5C21, C5C22. I only need the components mentioned above and I am unsure about where to get them
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@phillip96884 these capacitors are all the same. They are 0.01µF 16V 10% in a 0402 package. I prefer Mouser.com or Digikey. com but ultimately you can purchase these where you would like to. I do not get any kickbacks for mentioning those companies. It is just my preference. Check on here for the caps. You can always use the mfg. part number and do an online search to find different vendors.
このアンサーは役に立ちましたか?
Thank you for the help
@phillip96884 anytime and best of luck with your repair.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 53
2 件のコメント
@phillip96884 Can you upload pictures of your motherboard that show the spots where the missing components should be?
Andrew S さんによる
I will upload some
Phillip さんによる
