メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2265回答 すべてを表示
Can I swap battery cells 6S to 7?
Long story short I have a 7 that has a battery so dead that the phone won't even detect it anymore. Is it possible that I can take the good cell off of a 6S battery and connect it to the iPhone 7's BMS to make a 'new battery'. It would only be temporary but I don't know if it's possible.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Actually, I'm going to disagree with @corbanizer and suggest that there's no real reason it wouldn't work. The base chemistry of the battery cells is the same; they both take the same charging voltage at roughly the same rate and the BMS will regulate that. I'm guessing he 6S battery is slightly smaller so it will have a marginally shorter run time, but I doubt it's enough to make a significant difference.
As Corban said, the best strategy would be to simply buy a new 7 battery, but honestly there's no reason your plan won't work. The only catch here could be physical limitations; the electrodes coming out of the 6S cell have to be similar enough in geometry that they can be connected to the 7's BMS, and the physical size has to be such that it will fit into the 7's battery compartment and let the connector plug in.
If you do go ahead with this, be sure and come back and show us pictures of either the process or the finished product and let us know how it worked. Success stories are always appreciated, and we can usually learn something even when things don't go as planned.
Oh, one last thing; the best method for working on batteries is using a spot welder, as it minimizes the heat the battery cell is exposed to. If you don't happen to have one of those little devices, then solder carefully and use as little heat as possible; just get them tacked on so there's a good electrical connection.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Currently working on trying this out, so far the hardest part is trying not to be scared of the batteries and getting the BMS out of the adhesive shell they're in. Will keep you posted and thanks for your detailed answer :)
さんによる
Update: damaged the BMS flex so couldn't continue, ordered a new battery with next day shipping
さんによる
@keiranmelton Aw rats, I was looking forward to the experiment. Well, at least that'll get you going.
さんによる
コメントを追加
I wouldn't try it. Apple is known to not like that kind of thing and they have compatibility issues. I would just buy a new Iphone 7 battery and do it right the first time. Buy Once, cry once.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Keiran Melton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 55
