Where are the diagnostic LED’s located?
With power connected, I see no lights.
この質問は役に立ちましたか?
Hello, I don't have the motherboard diagram on hand but the indicator light is easily visible, if there is no indicator light on, first check the power supply outputs with the multimeter.
このアンサーは役に立ちましたか?
Thank you for responding. There are many comments on the web about these indicator or diagnostic LEDs but none of the associated pictures match my EMC 2374 logic board so I’m still trying to find their location. I do have a simple multimeter and can measure the voltage going into the power supply but I don’t know where to measure it’s output. There is supposed to be a “trickle” voltage being output when the unit is plugged in but not powered on.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 19
今までの合計 61
