メインコンテンツにスキップ
2019年2月に発売されたSamsungの10世代新モデルGalaxyスマートフォンの大型版です。Android 9.0 (Pie)搭載。
110回答 すべてを表示
Potential hurdles replacing the motherboard
Hi All! Planning on doing a motherboard swap to fix a charging port issue a friends phone has been having recently, are there any hidden connectors or potential pitfalls I should look out for? At the moment it only charges wirelessly, and in Samsung's infinite wisdom, they've soldered it to the board directly. Its more economical to get an entire new board than for someone to resolder it surprisingly. Thank you all in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi @ezzgen
Maybe check if you can find the problem on the motherboard before replacing it with another.
Here's the service manual for the phone.
Go to p.84 Sect. 8-4-6-1. to view the Cable Charging Part (Normal/Fast) troubleshooting flowchart.
Use Ctrl +f to find the components mentioned in the flowchart in the board layout images on p.76-p.77 (you will have to zoom in to 400%+ to find and see them :-).
The parts list is on p.29 -p.42 so if you find a faulty part the part's ID and part number can be found there. Search online using the part number only to find suppliers.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Unfortunately its the port itself, it works if i hold it at a certain angle but not at any other, and there's nobody local who does microsoldering for <£100, a board from a local seller is only about £30, could always be worse though!
さんによる
@ezzgen
Shame about not finding anyone who could replace the port cheaper, given the price of the part #3722-004150 but then again a good tech is worth the money in my opinion, but I'm biased
Cheers
さんによる
@jayeff No worries! Probably just the universe telling me to learn how to microsolder-
さんによる
コメントを追加
回答を追加する
woah its ezz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 86
