メインコンテンツにスキップ
True wireless earbuds case battery
Hey repair friends,
I have some LYPERTEC Z3 Earbuds (Not the ones in the header! But I had to choose something!) . I love them, but the Battery in the charging case does hardly hold a charge anymore.
I opened the case, no problem. Found the specs of the Battery (Type: ETL 902535 , 3.7V 800mAh 2.96WH)
Does anyone know where and how to find a Battery to replace the original? That would be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @jens65174,
Usually the number string on a LiPo battery denotes the dimensions of the battery.
Regarding the battery dimensions shown on a LiPo battery, the convention used in battery manufacture, is that the first two digits is the height (depth, thickness) of the battery, in mm (millimetres) with a decimal point between the two digits, but it is not shown, the next two digits is the width in mm and the last two digits (or sometimes three) is the length in mm, e.g. 902535 = 9.0mm height x 25mm width x 35mm length
If it is the same size as your battery, then here's a supplier. There may be others I didn't search too hard. ;-) Search online for 902535 3.7V 800mAH LiPo battery to find other suppliers that may suit you better.
Note: The ETL marking is a battery certification mark for the battery.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thak you for your prompt answer! Tis actually helped a lot! Thank you
さんによる
コメントを追加
回答を追加する
Jens さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 367
