Black screen and the power button is broken, what should I do?
Black screen and the power button is broken, what should i do?
You should most probably look for a repair. If you follow the guide iPhone XR スクリーンの交換 you will find everything you need to fix your screen.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 22
About the power button, is it cracked? bent? or does it just not work?
If it doesn't turn on the phone but presents no damage it might be an issue with the screen instead.
carlotremolada さんによる
