メインコンテンツにスキップ
Released in 2020, the Razer Blade 15" Advanced model is designed to provide gamers with powerful specifications and sleek aesthetics.
Ifixit 2020 Razer Blade 15 Advanced battery compatibility
Has anyone tried using the RC30-0248 Razer battery ifixit sells for the early 2020 Razer Blade 15 Advanced on the 2019 Razer Blade 15 Advanced that has the same RC30-0248 battery in it? Ifixit cannot confirm capability. Seems it should be fine.
Thanks
Replace a 5209 mAh battery compatible with your Razer Blade 15" 2020 Advanced model Laptop. 80.2 Watt Hours (Wh). 15.4 Volts (V). Part #RC30-0248.の画像
製品
Razer Blade 15" Advanced Model Laptop Battery
$92.99
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Did you ever figure it out?
さんによる
コメントを追加
1 件の回答
Using a battery not specifically confirmed by the manufacturer for your device can be risky. While the RC30-0248 battery may physically fit in both the 2019 and 2020 Razer Blade 15 Advanced laptops, there can be differences in voltage, capacity, and compatibility that are not immediately apparent. It's best to contact Razer's official support or check with Razer user forums to see if others have successfully used the RC30-0248 battery from iFixit in the 2019 model. It's essential to ensure compatibility to avoid potential damage or safety issues.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bloatedbattery さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 253
