Why is my new laptop windows corrupt?
Why is my new laptop Windows corrupt?
It might be the files got corrupted while trying to update the laptop software. Try having it boot up with an external usb drive with another version of windows in it and reset the laptop with that.
このアンサーは役に立ちましたか?
It can be repaired by usb drive or flash drive containing window that you want to install
It can be corrupt when you shut down your laptop when the screen is freezed it makes the laptop corrupt personally I have encountered this problem
このアンサーは役に立ちましたか?
It can be fixed by using a boot usb drive or flash drive that contains window that you want to install
I can be corrupt when you shut up the laptop in between a screen freeze or any software update btw I have encountered this problem
Kartik
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 95
Could you please give some more details?
Your question could mean almost anything.
Does it boot up for example?
mike さんによる
@vishuyadav Please explain the problem in more detail. Take a look at the details mike is asking for. In addition, take a look at the How to ask a good question on iFixit guide for instructions on how to better ask your question.
Andrew S さんによる
