My Brother printer MFC-L8900CDW leaves dents along the entire page
If the dents are evenly spaced, measure the distance between them and check the Brother site for "printed pages have repeating dots, spots or smudges". That may lead you to the component causing the dents.
このアンサーは役に立ちましたか?
Hi @robertmgariano,
I've experienced a similar issue with the brother L8900CDW. I found the issue to be the orange fusion roller becoming damaged due to overheating. An easy way to tell is by opening the back panel, pulling down the 2 green clips, and checking the orange roller for any visible damage. I hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 54
@robertmgariano Please explain the problem in more detail. Take a look at the How to ask a good question on iFixit guide for instructions on how to better ask your question. An image would also be helpful. iFixitでの質問に画像を追加する方法
Andrew S さんによる
