メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2614回答 すべてを表示
Replace battery in Samsun "Smart" solar remote (RMCSPB1EP1)
Has anyone managed to open their Samsung TV "smart" remote (Part no: RMCSPB1EP1) with the solar panel?
Mine is no longer holding charge (only 2 or 3 years old) and I'd rather open and replace the battery than throw away an otherwise perfectly functional remote and have to pay AU$130 for a replacement remote.
Samsung are promoting the remote as being "eco friendly" because it doesn't take alkaline batteries, but they've made sure it's very hard to get into to replace the (presumably LiPo) battery.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Use this link to examine an opened remote; https://electric.garden/samsung-a3l/smar.... Examine and enlarge the images for clues for mounting hardware or lack of them. If mounting screws aren't visible, they may be hidden under labels. Use a small round object or fingernail and press on the label. Any depression may be where screws are and require peeling off the label. If screws aren't used, the case may snap together, requiring careful prying to find where the clamshell snaps together. If you are successful in disassembling the case halves, locate the batteries and either desolder them and/or attempt to power up the remote with AA cells temporarily wired in to see if the remote will operate. If the remote operates, you can search for replacement batteries. Good luck as it is a worthwhile project.
このアンサーは役に立ちましたか?
スコア 3
10 件のコメント:
Thanks mate - I'll have a look and see how we go :)
さんによる
Did you open the remote? I'm still trying:(
さんによる
I have managed to open the remote without damaging it. But unable to find the replacement battery pack online.
さんによる
Can you post a photo? I’m probably going to have to go down the same route rather than spend €60 every two years!
さんによる
@thomassibu If you do as @simonjones83784 suggests and post a photo of the battery, it's entirely possible the iFixit community may be able to help locate one; I've rebuilt battery packs where I couldn't locate the exact replacement.
In addition, as Simon was asking, it would be great if you could also add pictures of what it takes to open the remote up since you've discovered a secret that has eluded many others.
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
Ben さん、ありがとうございました!
統計データ:
過去 24時間: 28
過去 7 日: 169
過去 30 日: 871
今までの合計 4,975
