New 2DS XL Won’t Power On
I just replaced my New 2DS XL’s motherboard. The old board had CFW and the new one does not.
The second the screen turns on, the system immediately shuts down.
Can anyone help with this issue?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like you might not have connected the cables quite right, probably one of the display cables. Open the console up again and try reseating them. The N2DS is notoriously picky about cable placement, so it might take a few tries. If that doesn't work, double check the rest of the cables too, and reseat any that look at all misaligned. I've heard of the ones near the ZL button causing a similar issue, so inspect those extra carefully
このアンサーは役に立ちましたか?
The last sentence you said was absolutely right. Thank you so much!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 45
