メインコンテンツにスキップ
インターネットから猫の画像をダウンロードしてレンダリングするようにコンピュータプロセッサに指示する機械が読み込むことができるインストラクションです。
210回答 すべてを表示
締切られた回答
Anyone with experience on Creating Setup/Self Extracting file
I am currently attempting to create a little setup file/Self extracting file that I can run to basically cut out the need to copy and paste the same files over and over again on multiple machines on a day to day basis.
This will be run on Windows Vista and Windows 7 Operating Systems. I have tried to use IEXPRESS through Windows but when selecting the files to add into the setup file it will not allow me to add folders, only single files. I have also attempted to use Winzip Self extract program, but I am getting stuck when it asks for the 'command'.
I need to be able to contain folders and files, have them extracted to one directory as a whole and then one file extracted to a seperate location (Desktop). Has anyone had any experience in this situation or know a piece of software that can help me in my time of need?
Many thanks in advance,
Wes
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hmm, this must have been moved. I answered where you originally posted the question. Winzip won't create self-extracting .exe files unless you buy the full version.
However 7zip is open source and will create self-extracting archives.
http://www.7-zip.org/
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
I love 7zip, have it installed on all my nonMacs, however it will not unarchive to multiple locations as they need - to the best of my knowledge. However it is worth looking into the possibilities with 7zip. Look out for the toolbar it forces you to install on versions over 9 - it will manipulate your searches. This task can easily be done with WinRAR. You can do program installs with it.
さんによる
Thank you, I will give both 7zip and WinRAR a go.
Many thanks,
Wes
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,146
