Where can I find outer case for this laptop.
I have done some updates on this laptop model and have not had luck finding an other case original or aftermarket
Hi @yuriat90
If you mean the bottom cover search online for L53531-001 (supplier examples only) to find suppliers that suit you best.
If you also need the rubber feet strips, search for L53558-001
The part number for all the parts can be found on p.15→p.18 of the hardware maintenance manual taken from this support webpage for the laptop.
Usually the HP part numbers can be found on the part itself, somewhere if you wish to verify, but with the bottom cover you would have to completely dis-assemble the laptop to see it ;-)
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 107
