メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
423回答 すべてを表示
Bluetooth not working, even after module replacement
I have a MacBook Air early 2017 where I can't activate Bluetooth in system settings (or in the menubar). When clicking the switch nothing happens, stays gray.
  1. I have tried to reset NV-ram and SMC.
    (Other reset options for BT is not available/doesnt show up.)
  2. There is no com.apple.Bluetooth.plist in /Library/Preferences/ to remove
  3. Wifi is working fine.
  4. Same issue even after replacing Wifi/BT module.
    Wifi is working fine. Unable to activate BT.
    Please bring up you ideas on what's the problem or if you have any solution or idea on what could solve the problem.
    Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I'd recommend booting into Safe Mode or reinstalling the OS from Recovery Mode to see if the issue could be a software problem. You could also create a new user account to see if the issue still occurs in a fresh software environment. If you've ruled out software, and replacing the AirPort card doesn't fix the issue, then there could be a problem on the main logic board. It might be worth inspecting the condition of the board to see if there are any signs of corrosion or other damage. Good luck!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for your answer!
I made a fresh install from recovery mode and then recovered users from a Time Machine backup. But I haven’t tried creating a new user. Will do that!
さんによる
@ola39360 Best of luck! Let us know if you find a solution.
さんによる
コメントを追加
回答を追加する
Ola さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 30
