メインコンテンツにスキップ
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
470回答 すべてを表示
Apple Pay Doesn't Work
I bought a 2nd hand iPhone XR from someone I knew who had owned it from new. It was a temporary phone while my iPhone 11 was being repaired. Unfortunately, Apple Pay didn't work. I tried a separate NFC tag and still nothing. I ordered a replacement part as per the images shown (not the charging coil, the small little flexi circuit that runs up close to rear-facing camera) and still it does not work. Is there an on-board component that could be faulty?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It sounds like you replaced the wifi flex and not the NFC flex. Check for corrosion or damaged flex cables around the Wireless NFC Charging Flex and connector on the motherboard sometimes the foam around the connector gets in the way of the pins. It's an inexpensive part so I would just replace it. If that doesn't fix it then your NFC IC chip on the motherboard is probably fried. It's very common for the NFC charging flex to get damaged during back glass repairs so I would bet on that being the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chris Halliwell さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 5
今までの合計 48
