メインコンテンツにスキップ
Power Bank is a kind of battery you use for charging your devices just in case it runs out of battery at somewhere you can't charge.
20回答 すべてを表示
My power bank is unable to charge and to be charged
My power bank suddenly stop charging and it is also unable to charge any of my device. What should I do to repair it please? It's an oriamo power bank
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@law23805 attach an ammeter to it and see if your power bank still pulls a charge. If it does not check the charge connector and make sure there are no bend/broken pins, no corrosion and no debris in it. You can clean it will a few drops of isopropyl alcohol and a few puffs of air-in-a-can. If that does not resolve it, time to open it up and take a look at the charge controller board etc. and post some good pictures of what you find. Everything will be a guess until we see what is going on with it,
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Law さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 14
