Fingering is disappeared in my settings
Fingerprint sensor is disappeared in my settings
@raorajput update your software first. If it still does not show after you upgrade your software, it is possible that your fingerprint sensor has failed and thus your software can't find it. Check on here for the setup and on here for possible fixes. Different model, same idea. If none of this works, you may need to replace the sensor. Problem is that guides for this are not easily found
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 32
今までの合計 1,054
6 件のコメント
Fix a network problem
Aziz さんによる
Infinix not 12 in no fingerprint work
Anup Kumar さんによる
Touch screen problam
So cut 24 So cut 24 さんによる
Bikesh Majhi さんによる
Not work fingerprint
Broken Boy さんによる
1以上のコメントを表示
