I Phone cycling on and off
iPhone cycling on and off attracted is analytics
(thermalmonitord Missing sensor(s): mic1) This panic log error code usually points to a faulty charger port flex and will cause a 3 minute boot loop on most iPhone devices. Change out the charger port flex with a good quality unit and this should fix the issue. There is a Panic Log Analyzer Tool available for windows that you can use to check the codes:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 26
