メインコンテンツにスキップ
Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
8回答 すべてを表示
Won’t turn on
Hi, I have a CitiZ and it’s not turning on. Which internal component is likely to be causing the problem? I have an old Magimix I could use some of those parts. Any help would be appreciated. Thank you. Hi, I have a CitiZ and it’s not turning on. Which internal component is likely to be causing the problem? I have an old Magimix I could use some of those parts. Any help would be appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Do you have a model with a dedicated on/off switch on the right side base?
If it's not the power supply/ cable, then it could be the electronics.
In that case, you'd have to check and compare if the PCB of your Magimix (it is a Cititz, too, isn't it?) is identical to your Citiz. As I have seen the order of the connecting cables on the PCB change from model to model.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Georgia さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 17
今までの合計 61
